Hi, thanks a lot for sharing this information as my U25 burnt the exact same way.
Did you were successful repairing it by replacing the part?
Edit: If my calculations are right, this part is a quite common DC/DC step-down converter configured for 1.2 volts output. I have a couple very similar with the same pinout lying around, so I tried replacing the broken SY8201 with a MP2459GJ-Z (and adapted the value of the two R2 resistors from 19k to 30k). Unfortunately in my case the EN pin of the step-down won't get active anyway (maybe because of another fault). I think I'll see if I can get a cheap replacement board on ebay or the like...
