perieanuo: Thank you so much, I believe you nailed it. The data-sheet lines up with the board values.
I do a lot of these sans-schematic but some just turn into a PITA. Most end up being shorted caps pulling down the voltage. Some run me in circles.
amyk: Thanks for the suggestion. I will certainly keep it in mind going forward and I have taken a shot of the same component from another board currently on my bench for comparison.
Thank you both for your timely and helpful replies.
-Cheers
