Got my dirty hands on a lovely Juki industrial sewing machine. This is a perfect toy for me as someone who likes both mechanics and electronics. Its head unit is in reasonable condition with signs of wear and tear (it's not a casual machine so this is not a surprise). But the rest, such as motor, control box (the box below the motor under the table), CPU mox (the robot like small box above the table), are all in mint condition.
This was after I repaired, or tuned, a handful of domestic sewing machines and looked into another Brother industrial machine. This one impressed me and I really want to get it running the way it should. Its look is sleek without exaggerated masculinity (though it is powerful). Its electronics design is elegant and compact. Its design is highly modular, with plenty room of for different sorts of adjustments, and other beautiful features. The only aspect that loses to the Brother is the pedal sensor module. Well I've got into too much detail that you might not be interested.
When I got it, the motor ran when turned on, and the head unit also ran for a second or so without pressing the pedal then stopped. After that no reaction to the pedal. After some fiddling around, I don't even exactly know why it started getting 'better'. The motor always runs well when turned on. The needle responds to the pedal, running when pressing the pedal forward, and accelerating when pressing hard. The thread trimming mechanism (driven by a solenoind) works as well but the timing is incorrect so breaking the needle (the knives action when the needle is down, which is wrong). Although it would be great if this can be fixed it is not the biggest problem, because this feature is not essential I can simply disable it if cannot be fixed. The biggest problem now is that the needle does not stop immediately when the pedal returns to the neutral position. It stops, but not immediately. Without this being fixed, the machine is useless, because it does not stop sewing when you want it to stop.
I've tried all I can, including disassembling and reassembling the pedal sensor module, the synchroniser module, tuning the delays with the pods inside the control box. I've also read the service manual carefully for many times and have exhausted what I can think of. In case someone has experience or is interested in helping me crack this. It's quite a challenge, so this is an invite!
The service manual is available here
https://s3.amazonaws.com/a.teamworksales.com/JUKI+ENGINEERS/DDL-555-5_100%26200%2CEngineer%27s+manual%2C(No.I-14).pdf. The level of detail and clarity is impressive given the age of the machine (I think its manufacturing was from the end of the 1960s to probably the 1980s).
Since it's very rare when a sewer is interested in electronics, there is little, if at all, information on youtube related to this.
P.S. Well I said I've tried all I could, but I've not really got into the electronics yet, i.e. tracking the signals in relation to the pedal positions etc etc. This is probably what I should do next. It's only not as wieldy as a little box that I can put on the desktop and toss around.
