Assuming pin 1 is the base it goes through a 2K series resistor to the collector of an NPN transistor. When I test the collector (pin 3) and emitter (pin 2) in diode test mode with positive terminal on pin 3 I get a forward voltage of .624v. No other junction tests show any forward voltage. Holding the positive terminal of the multimeter on pin 3 then touching (momentarily) the negative terminal to pin 1 causes pin 2 and pin 3 to have continuity for a few seconds and the returns to open circuit. Keep in mind I'm assuming base, emitter, collector for pin 1,2,3.
Might it be a p channel mosfet?
Hope this info helps.
Jerry
