A woman friend of the family has brought this unit to me to see if I can remedy its problem. Problem being, she’s found that the unit doesn’t pump her tires anymore — simply doesn’t start building any pressure within the unit.
To be specific, this is a Stanley 500 AMP, Jump Start System, model J5C09CA — a combination jump starter, battery charger, and compressor.
The lady says it was working for her within fairly recent months. She was keeping it plugged in, apparently over a long stretch (she thought this was a good idea, but I haven't seen the manual for it, and don’t know if this is recommended).
Neither the compressor nor the battery boost/charger function works when connected to 120v AC line current that is standard in our area. I attempted to test the charger function by connecting the unit to a battery of mine, a 12v-DC lawn-tractor battery. There seemed to be no juice going to the battery. BUT what did occur is that when I tried the compressor with the battery connected, it actually ran!
Without any reference to a manual, I just guessed that the compressor should operate by line current alone (and not be dependent on external battery power). I'm guessing the internal battery in the unit must be ruined. I have no experience opening one of these up, but I'm a generally handy guy — I weld, fix small engines, have wired a couple of shops, etc. With a little hand-holding, I might be able to fix this thing. THANKS.
