Author Topic: Just a shot in the dark ( IC identification help )  (Read 675 times)
Offline gearheadgeekTopic starter
  • If its not broken still tear it apart
« on: July 11, 2024, 09:54:25 pm »
Hey guys I did something stupid I let the magic smoke out but anyway. It is a Chinese device but unfortunately I can’t read the rest of the marking so this is a shot in the dark to me and I wear trifocals it looks like a 555 timer I can see some markings but I was thinking maybe you guys may have run into one of these IC with similar markings. If not Advanced thanks anyway
Offline Ian.M
Re: Just a shot in the dark ( IC identification help )
« Reply #1 on: July 11, 2024, 10:04:47 pm »
I think we can be fairly sure its *NOT* a 555 timer.  However without seeing the rest of the board and having an idea of its application all we can do is guess from the remaining markings.
Offline thm_w
  • Non-expert
« Reply #2 on: July 11, 2024, 10:37:18 pm »
You need to reverse engineer a schematic or find someone else who has taken apart the same device and has a photo.
Offline wraper
  • Country: lv
« Reply #3 on: July 11, 2024, 10:44:18 pm »
At least give some context about what it is. Showing a picture of IC with destroyed marking with no other info and not even a PCB picture is not helpful.
Offline TheDefpom
  • YouTuber Nerd - I Fix Stuff
    • The Defpom's Channel
« Reply #4 on: July 11, 2024, 11:32:40 pm »
We definitely need a LOT more information, what is the device it is used in?, what is the identifier on the PCB, is it U5? (in case someone has diagrams for it).
Cheers Scott
Online DaJMasta
    • medpants.com
« Reply #5 on: July 12, 2024, 07:21:02 am »
TR___6
Offline Harry_22
« Reply #6 on: July 12, 2024, 08:31:33 am »
TR4...
Take photos from different angles to the light.
