Most likely bad solders, start by any large and/or hot component those are the ones that stress solders fastest. (Regulators, power transitors, >1W resitors, VFD filament)
Then there's the interconnect, the wires pull on the PCB side of the connector and weaken the solders there too.
Also look around the 2 large capacitors, this model looks like it may suffer from glue corrosion. The glue used to stick the capacitors can corrode components that have been covered with it, not always obvious and can cause unexpected faults.
Make sure you don't destroy one of those Super-A voltage amplifier IC's, I'm sure they're very hard to find now.
