It's been only a few days since I've finished torturing you guys with my previous riddle, and now I've picked up a bunch of old Saticon based cameras from a friend. Guess that's what funemployment does to you keeping your hands open!
The set consisted of a more-or-less working JVC GX-S700, a portable VTR+tuner dock combo, and a JVC KY-1900. The VTR wouldn't turn on — I suspected capacitors and undervoltage, turns out one of the power transistors in the tuner's stabilizer went, and the VTR received 38V where it expected 12... Swapped that out with some junk power transistors I've had lying around and it's all now funky. Granted I have no use for it and will make an adapter to record video directly into my cell phone later down the line.
Now, onto the main star of the show... The JVC/Victor KY-1900.
![[Solved] JVC KY-1900 Triple Saticon Camera: blue channel is feeling blue 2124128-0](https://www.eevblog.com/forum/index.php?action=dlattach;topic=424442.0;attach=2124131;image)
On day 1, it powered up just fine, however, there was no blue channel whatsoever. Tube reconnections ensued and a few anode zaps to my finger later, I confirm the blue tube is well alive. In the end I come down to the fact the fault is located in the Process Board. This little dense thing here:
![[Solved] JVC KY-1900 Triple Saticon Camera: blue channel is feeling blue 2124134-1](https://www.eevblog.com/forum/index.php?action=dlattach;topic=424442.0;attach=2124137;image)
So, my first thing was, of course, to check the inputs and outputs of the HA11732 (
https://datasheetspdf.com/mobile/499542/Renesas/HA11732/1). Sure, the blue one has input but no output, so I promptly swapped around the blue and green ones. Surprise, the fault remained in the blue channel.
Now, I don't exactly remember the diagnostics steps I took — first I swapped all electrolytics in vicinity, even though they looked good, and measured fine (as much as my DMM allows — no ESR or leakage, only capacitance). No dice.
I've measured around the chips, and found out that pin 1 of the blue HA11732 is at around 1V, which is too low. The others are at around 4V. Probing around for shorts and things, I've noticed that between pin 1 and ground my DMM goes "bip..bip..bip.." as if there is "almost continuity". On the other color circuits, it doesn't do that. So I swapped the "blue droplet" capacitor (what are those called?), 1uF, for a 6.5uF one, as that was the closest of this type I've had on hand.
Start up again, seemingly no dice — but now the blue channel is constantly filled with color.
Then I've noticed that turning the black level trimmer on the blue channel (the closest to the stripe on the HA11732) to the minimum position makes a faint, noisy image appear. Respectively measuring the pin 1 when turning the black level trimmer confirms — in the minimum position it's at the "normal" voltage of 4.2V, but any position beyond that makes it skyrocket to 8V. On others, the trimmer moves the voltage in small increments from around 4 to around 6V. Additionally, the Knee and Clamp adjustments don't make a difference on the blue circuit.
I thought, maybe an opamp is wacky — one of them was getting pretty toasty when the blue channel is "filled", and the pins on it look rusted. Swapped them around, no dice.
At this point I've also taken out and checked most transistors in vicinity (see white dots on the photo) — all are "fine" (not shorted, not open, but can't test further). Ceramics and the green (what are those called too?) caps are seemingly OK as well. I didn't bother with the resistors for they are too tiny. Diodes are OK too. And of course I washed and cleaned all the trimpots, so they output super smooth with no crackle (tested on a scope).
The TA chips are the input amp, so that stage is fine (and swapping them around makes no difference). The TC chips are logic, and are for the color bar generator, not the primary video circuit.
I feel like I'm missing something very simple here. Does anyone have experience with such cameras, or maybe the circuit diagrams or service manuals? Or maybe someone has seen those HA11732 chips in a similar setting previously?
So far I've tried to dial in the rest of the calibration with the current state of things, but it looks very sad and far from what this camera can actually do:
![[Solved] JVC KY-1900 Triple Saticon Camera: blue channel is feeling blue 2124140-2](https://www.eevblog.com/forum/index.php?action=dlattach;topic=424442.0;attach=2124143;image)
(also you can clearly see on the spectroscope how the blue channel is clamped down)
Calling for help to the wizards of the tech past! Thanks a lot in advance for your help.
