Leds burning down are very common in older TVs as they age.
In fact, I usually found more damaged LEDs, but "luckly" they were shorted, so the backlight still worked, until one of them failed open.
If it's for yourself and you don't want to spend money in new leds strips, a cheap fix is to short the open leds with a wire.
The LED circuitry works at constant current, it will work fine, won't overload anything.
Unless there're contiguous damaged leds, the light difference isn't very noticeable.
Otherwise replace ALL the leds, or you'll have to fix them every 3-6 months. They all have the same running hours, so it's likely for others start failing.
