Hi!
Thanks for your help.
I managed to calibrate this power supply, and after calibration,
when I press the "On" button, the voltage first starts to fluctuate erratically,
and then the indicator shows "OUP."
This means the power supply automatically shuts off the output voltage
to prevent damage to the device connected to it.
I checked all the electrolytic capacitors, and they're fine.
There might be something else going on.
