After a bit of a search, I found an extra, new KBIC-125 that I bought in about 2003. I never throw away the manuals, but I couldn't find this one. (My stuff is spread currently between 2 houses 42 miles apart.) But, I did pay $50 for it.
Attached is a picture of the installation on my Prazi miniature lathe. I also found this online:
The KBIC® can also be operated in a voltage following mode by supplying an isolated analog signal (0 – 9VDC) to the input
terminals P2 (+) and F-.The controls are terminated as standard with Q-D terminals.
As I recall, the KB controls I have can all be operated by a potentiometer or variable DC voltage. None of them are current controlled.
Maybe that helps. I will probably go to the other house Thursday and will look for the manual there.
