Hello,
Well i have the following issues with my 199.
When in OHM mode i got under different ranges different readings. For example i've measured 10k resistor and sometimes it measures as it should, but if i measure it again it shows 23k. Also when i switch on autorange function under resistance mode, it does not works as it should. Display toggles between K and M letters when measuring 100k resistor. Lower resistance values are measured fine and accurate when autorange enabled, but if i manually change ranges it shows different values under different ranges...
So what could be the cause of the problem? All other functions works fine and with good accuracy.
Thank you in advance!
Regards,
Hrvoje
