Hello forum!
A long time ago when I was a child, I had a nice R&S power supply which my father provided me to power my small electronic projects.
Sadly, one day it became defective, IIRC due to a prolonged (almost-)short circuit on it's output. I do not remember what we did try to fix it, but apparently we could not fix it. But I also never wanted to throw it away, so it lived in a box for many years. Recently I found it again and decided I wanted to give fixing it another try. So much for the history.
The current state of the supply is that it turns on, but only gives a small negative output voltage of ca. -0.6 V, regardless of the voltage pot's position. The left LED (CV mode?) is lit, the right one (CC mode?) not. The current limit pot has no effect. The meter in voltage mode shows the negative DC voltage (offset to the left), in current mode it shows 0.
After opening up the case I discovered that we back then replaced one of the resistors (I suppose the current shunt) with a self-wound piece of simple isolated wire... Whose value most probably would be wrong. The missing/wrong resistor is labeled "R310".
Sadly, I could not find any schematics or even a manual for the power supply online, so I have no idea what the value of the original resistor once was. Could anyone help me with that? I suppose it's not the only fault in the unit (i think at least one semiconductor will be faulty), but would be a start. Of course having schematics would greatly help fixing the supply...
Sorry for the long text and thanks for reading!
Kind regards,
Stefan
