Dear forum,
My K2000 is ill again
. About a year or two ago I repaired the front panel: I replaced VFD along with one driver. As far as I remember everything worked back then. I didn't use my DMM much since then. It was stored in a box, and was relocated to another place by a car (I was gentle with it).
Today I powered the unit and found that
some keys in the bottom row don't work. The unit works well otherwise, I don't see any other problem.
Do you have any suggestions why that could be? I tried to trace the problem, but so far no luck. What I tried:
1) measured potential between contacts. On top row there is 4.8V between buttons contact. But now voltage between contact on buttons on bottom row. Yet a few buttons on the right work somehow. I don't understand this.
2) I tried to track traces from non-working buttons, they go to an IC marked as 2000-800A02. The contacts are fine.
3) I did quick inspection with a microscope, nothing suspicions at first glance, except a few strands in ribbon cable were broken where it connects to the board. I repaired this. It was first two contacts, one is unused, another one is gnd, but there are multiple gnd connectors, so I don't that was problem. After repair the front panel still behaves the same.
So, my best guesses are:
1) 2000-800A02 is broken (not sure what it does, but I think it's an mcu, sticker covers the part number
2) there is some other trace is broken which I haven't found yet
New ideas are welcome
Why I need the bottom row: I need to enable rs-232 interface for logging. It is enable by the button that currently doesn't work. That's how I found out that my K2000 has a problem.
