Thank you, Samogon.
This is a very kind offer and I do appreciate it very much.
I am not a complete novice and have done a fair share of removing large connectors. However I do not solder on a regular basis and I never worked on the instrument this sensitive before, so I may need some guidance.
I do have a vacuum desoldering station (very old PACE Micro that I bought used and fixed). I am planning to modify one of the tips to work with slightly bigger 40 mills legs on the switch. I also have an ESD mat to work on.
The questions that I would have are:
1) Should I wear gloves? What kind (rubber/cloth)?
2) Is using regular 60/40 solder with flux core good enough, or do I need some kind of low thermal solder for the switch?
3) Is alcohol (or samogon
) sufficient for cleaning after soldering
4) Are there any special tricks or tips for removing Analog and Digital boards from the case?
5) Should I replace capacitors that are far away from the transformer and voltage regulators?
6) In some videos, including TiN's video of K2002 repairs, I saw new solder being added to the joint before desoldering it. Why is that?
Thanks in advance for answers.
In case someone would find this useful here is a list of every electrolytic capacitor in K2002 with their DigiKey part numbers. They all are Nichicon beside 15000uf that is Illinois Capacitor (Nichicon was not in stock anywhere). Most original capacitors are VX(M) series and these are these UVX series. I am hoping these are essentially the same.
Index QT Part Number Description Cust Stock Backorder Unit Price USD Ext USD
1 1 UVZ1H102MHD CAP ALUM 1000UF 20% 50V RADIAL C104 1 0 0.94 0.94
2 2 493-1323-ND CAP ALUM 2200UF 20% 35V RADIAL C112,C113 2 0 1.31 2.62
3 1 493-1288-ND CAP ALUM 2200UF 20% 16V RADIAL C114 1 0 0.72 0.72
4 2 493-1358-ND CAP ALUM 470UF 20% 63V RADIAL C116,C117 2 0 0.76 1.52
5 2 493-1322-ND CAP ALUM 1000UF 20% 35V RADIAL C118,C119 2 0 0.7 1.4
6 1 493-1266-ND CAP ALUM 100UF 20% 10V RADIAL C206 1 0 0.28 0.28
7 3 493-15350-ND CAP ALUM 22UF 10% 16V RADIAL C247,C250,C253 3 0 0.38 1.14
8 1 1572-1350-ND CAP ALUM 15000UF 20% 16V AXIAL C611 1 0 5.15 5.15
9 3 493-1287-ND CAP ALUM 1000UF 20% 16V RADIAL C624,C630,C633 3 0 0.52 1.56
10 1 493-14496-ND CAP ALUM 47UF 10% 35V RADIAL C625 1 0 0.45 0.45
11 1 493-1369-ND CAP ALUM 2.2UF 20% 100V RADIAL C912 1 0 0.28 0.28
