Firstly, hope everyone is doing OK, considering world events.
Secondly, first time here, so please be gentle and I did search the forums, but coudln't found much on my particular issue (even several evenings of googling let me down).
Situation: I scored a Keithley 2010 DMM from the "not worth repairing pile" at work and thought it'd be fun to get it working and have a nice 7.5 digit DMM for the lab (better than the old Solartron 7045 I've had for years!). I did scour the forum and found the partial schematics and user guide/service manual, but no many other posts on this particular model or similar issues.
Problem: Boots fine, but goes into "overflow" on all ranges and input types. Opening it up showed no visible magic smoke release, borken caps or anything fishy... Damn. There was a rare case where I saw some random digits, when I wasn't ESD grounded and poking some of the input wires.... Soon as I got the ESD mat out, it was overflow all the time.
So far:
- I measured all the voltages which generally seemed OK. 5V digital rock solid, 5V analogue was a little high and very hot. Hmmm. +/-15V rails seemed OK at 15.6V, but the supplies to the split rails, namely +/-24V and +/-18V are a bit on the high side...
- Thought the 5V analogue rail was a bit too warm.
- Confirmed that the front panel/main board digital section is working fine.
- Traced the comms from the digital section to the OKI chip in the analogue section. Can see data going back and forth, which changes when I chose different ranges/modes.
- Traced the tracks for the shift register (from the partial schematic) and confimed that all the clk/data/strobe lines are there.
- Traced the shift register data through all the chips and found it wasn'ty getting to the last two chips in the chain. Hmmmm interesting...
- I then confirmed that the ULN2003 (for driving the relays) connects to one of the suspect shift registers, so no wonder it's not switching!
- I checked the power pins of the suspect shift registers and low and behold, there's a short on the 5V analogue plane!?
- I checked other parts of the 5VA plane, yep shorting; however some of the +5V/0V points are 50R 5V->GND ?!
Solution: In progress...
So, before I start systematically pulling each 5V crossing component to find the one that's shorting, anyone seen this sort of thing before and can suggest any cuplrits? The dreaded multi-element switch or something more sneaky?
Cheers and thanks in advance,
danoki
