It is a 6PDT switch. I did the replacement a couple of months ago. If I remember correctly, I used Mouser 611-SF6UEE. The only problem I had was that the switch body was about 1 mm longer than the original one and it hit the component at the rear of the switch. But it was easy to bend the leads of the component and move it a bit.
