Good morning,
I continue my attempt to repair my keithley 2015.
And I come back to ask for your help
When switched on it displays "no comm link"
I have read all the posts on this forum dealing with this issue.
All the comments are excellent and I learned a lot about the operation of these devices (k2000, K2015)
After having eliminated the problems of contact braid, capacitor, rom ... I have come to the conclusion that the problem may have come from the optocouplers of the analog/digital part.
But if I understood the operation of a simple optocoupler (with 4 legs) I have much more difficulty understanding the operation of an optocoupler with 8 legs (I am a small amateur in electronics),
Also, knowing that the k2000 and k2015 share the same main board, I bought a k2000 (in perfect working order) so I could compare various voltage measurements.
It was indeed the only way I saw to try to find the failure of the 2015.
I compared the various voltages at the legs of the optocouplers (a2601, a2611) of the two devices and found the following differences:
- A2601 - leg 6: k2000: 1.62 v k2015: 255 mv
- A2611 - leg 6: k2000: 351 mv k2015: 5V
I have respected the masses AGND and DGND
I am attaching a drawing of the tensions observed at each leg.
Do these observed voltage differences suggest that the optocouplers are faulty?
Is there another way to test them?
thank you for any help
