Sorry for yet another Keithley 2*** re-capping thread, but I have a few questions which I haven't seen answered in other threads. (Or I've missed the answers !)
So I have purchased a working Keithley 2015THD on Ebay and it was last calibrated Oct 2010 with a cal count of 6, which suggests that it's about 12 years old. Its version is: B15 A02, whatever that means !
I should stress that I really don't want to have to get it re-calibrated so whatever I do mustn't affect that. The Keithley manual stresses that it should be re-calibrated even after just removing the boards, although I'm sure mine is far enough out of calibration for that not to be an issue. Either way, I think I should be using gloves and making sure that I clean off any flux residue after I'm done.
So my questions:
1) What benefit is there to the later firmware versions ?
2) What's the latest firmware that's available to me without affecting my calibration data ?
3) Does anyone have a full part-number list (Ideally from Farnell or some other supplier who deals with the UK) for a full set of 2015 capacitors ? I'm looking for replacements which are an exact fit, I don't want to have them mounted on wires. (I've seen some for the 2000, but none of these were low ESD which seems incorrect and I believe there are more in the 2015 - Also I've heard that the list in the service manual is also incorrect ?)
4) What's the correct flux-cleaning method ? I never usually clean flux after soldering but I think I should be in this case ! I believe I should just be using Isopropyl Alcohol and some lint-free swabs - Is this correct and do I need to use anything after this ?
https://www.amazon.co.uk/500mL-Pharmaceutical-Isopropyl-Alcohol-Isopropanol/dp/B00WLAS9W8/ref=sr_1_1?ie=UTF8&qid=1472257138&sr=8-1&keywords=Isopropyl+alcohol+purehttps://www.amazon.co.uk/KTC-Computer-Technology-Cleaning-printers/dp/B01KS97MG2/ref=sr_1_8?ie=UTF8&qid=1472253486&sr=8-8&keywords=lint-free+swab5) Any other advice ?
From what I can tell from the manual (
http://exodus.poly.edu/~kurt/manuals/manuals/Keithley/KEI%202015%20Service.pdf), the following are required: (Sadly it doesn't give an information about pitch or ESR -
Also doesn't mention anything about C260 and C261 which are populated on some, will have to open it up and check but wanted to order the replacements before removing any boards I can confirm that C260/261 is not populated in my unit - Part numbers and sizes below are from the datasheets)
Main board- C104 - 100uF 63V 20% [Confirmed value in my unit - 85C / Nichicon VR(M) - P/N: Nichicon UVR1J101MPD / Size: 10x12.5 (Could replace with 105C version but this has a lower ripple current of 215mArms vs 300mArms: UVZ1J101MPD, no idea what effect this would have)]
- C131/148 - 2200uF 35V 20% [Confirmed value in my unit - 105C / Nichicon VZ(M) - P/N: Nichicon UVZ1V222MHD / Size: 16x25]
- C146 - 3300uF 16V 20% [Value in my unit is 2200uF just like in another thread - 105C / Nichicon VZ(M) - P/N: Nichicon UVZ1C222MHD / Size: 12.5x20 (The 3300uF version is 5mm taller)]
- C156 - 6800uF 16V -20+100% [Confirmed value in my unit - 85C / Nichicon VX(M) - Does not seem to exist in the datasheet]
THD board- C326 - 100uF 16V 20% [This is an SMD part, will not replace]
- C346/347 - 47uF 100V 20% [Confirmed value in my unit - 105C / Nichicon PR(M) / Size: 10x16]
- C562/565 - 1000uF 50V 20% [Confirmed value in my unit - 105C / Nichicon VZ(M) / Size: 12.5x25]
- C568 - 2200uF 25V -20+100% [Confirmed value in my unit - 85C / Nichicon VR(M) / Size: 16x25]
For C156 it looks like a VR/VZ replacement of value 10000uF 16V or 6800uF 25V would be the same physical size and hopefully the same lead spacing. I'm thinking the higher voltage rating is better so that the value is the same.
I doubt the ripple current will be an issue due to increasing the rating, therefore the 105C VZ is probably best. (P/N: Nichicon UVZ1E682MHD / Size: 18x35.5) Sadly Farnell don't stock the 105C VZ version so I might have to get the VR version which they do stock: Nichicon UVR1E682MHD I've decided to keep it as close to the original fitted part as possible, which means 85C where they had 85C capacitors and hence this for C156: Nichicon UVR1E682MHD Where I have to make an adjustment due to a part which no-longer exists, I'll go for an increased voltage range in order to get the right physical size.
Nichicon Datasheets:
I don't have an precision references so the most I can do in terms of calibration and verification is the nulling.
I also have a HP 6032A which is also likely in need of re-capping, but that's another thread.
Thanks.
UpdateAfter opening it up, it looks like there are a few parts which aren't listed in the manual at all. (C279, C280, C350) There are a couple where the series doesn't exist anymore (C346, C347) and therefore I've substituted a similar part that's slightly shorter but the same diameter and ratings. Additionally C326 is an SMD capacitor so I won't replace that at all. (I don't fancy using hot air around a precision piece of kit - That and I'm not 100% sure about the spec of the existing part.) The table below represents what I'll be ordering and replacing - Any comments ?
Parts List| Component Reference | Manual Specification | Original Part | New Part Number | Quantity |
| Main Board |
| C104 | 100uF 63V 20% | Nichicon VR 100uF 63V 20% 85C 10x12.5 | Nichicon UVR1J101MPD (100uF 63V 85C) | 1 |
| C131,C148 | 2200uF 35V 20% | Nichicon VZ 2200uF 35V 20% 105C 16x25 | Nichicon UVZ1V222MHD (2200uF 35V 105C) | 2 |
| C146 | 3300uF 16V 20% | Nichicon VZ 2200uF 16V 20% 105C 12.5x20 | Nichicon UVZ1C222MHD (2200uF 16V 105C) | 1 |
| C156 | 6800uF 16V -20+100% | Nichicon VX 6800uF 16V 20% 85C 18x35.5 | Nichicon UVR1E682MHD (6800uF 25V 85C) | 1 |
| C279,C280 | Not Listed | Nichicon VR 47uF 50V 20% 85C 6.3x11 | Nichicon UVR1H470MED (47uF 50V 85C) | 2 |
| THD Board |
| C326 | 100uF 16V 20% | SMD 100uF 16V 5x5 (Markings: "ON 100 16F") | Will Not Replace | 1 |
| C346,C347 | 47uF 100V 20% | Nichicon PR 47uF 100V 20% 105C 10x16 | Nichicon UPS2A470MPD (47uF 100V 105C) | 2 |
| C350 | Not Listed | Nichicon VZ 4700uF 16V 20% 105C 16x25 | Nichicon UVZ1C472MHD (4700uF 16V 105C) | 1 |
| C562,C565 | 1000uF 50V 20% | Nichicon VZ 1000uF 50V 20% 105C 12.5x25 | Nichicon UVZ1H102MHD (1000uF 50V 105C) | 2 |
| C568 | 2200uF 25V -20+100% | Nichicon VR 2200uF 35V 20% 85C 16x25 | Nichicon UVR1V222MHD (2200uF 35V 85C) | 1 |
