Author Topic: Miele Control Board - Identify Power Supply IC  (Read 3728 times)
Offline Lion_TamerTopic starter
« on: February 04, 2016, 10:17:08 pm »
Hi All
I am trying to mend a control board for a washing machine where the power supply IC has blown but as yet I have not been able to identify it and wondered whether the vast knowledge and wisdom of the community here could help.
The details that I can make out of the chip are:
  • Make: Philips Semiconductor
  • Package: 14 Pin Soic
  • Line 1: ....2T
  • Line 2: ....935
  • Line 3: ....052
The board dates from around 2005/2006 era, I don't yet know why the chip failed but it is the only visually blown component, there is also a fusible resistor in the power feed to it that is OC.
The circuit layout around the chip appears to be this:
  • Pin 1: Decoupling capacitor to ground? also feeds into a couple of transistor?
  • Pin 2: Ground
  • Pin 3: Ground
  • Pin 4: Ground
  • Pin 5: Ground
  • Pin 6: Parallel Resistor and Capacitor to Ground
  • Pin 7: Parallel Resistor and Capacitor to Ground, also feeds into a couple of transistors?
  • Pin 8: Resistor to low voltage positive
  • Pin 9: Ground
  • Pin 10: Ground
  • Pin 11: 1 Ohm Sense resistor to ground
  • Pin 12: Not Connected
  • Pin 13: Not connected
  • Pin 14: Transformer Winding
Thank you
Jem
Offline rich
Re: Miele Control Board - Identify Power Supply IC
« Reply #1 on: February 05, 2016, 01:59:33 am »
Offline alsetalokin4017
« Reply #2 on: February 05, 2016, 03:25:39 am »
Looks very plausible. TEA1522T. Pinout seems to match.
Offline RichENZED
« Reply #3 on: July 08, 2016, 01:59:40 am »
Can I ask how you got on in the end?
I tried once in the past.
I had an exploded TEA1522t and bought a replacement from eBay.
Mine turned on but there was another fault where the water inlet valve operated continuously.
Did you have better luck?
