Author Topic: Keithley 2100 - DSP pin assignment/interconnection  (Read 371 times)
Offline Arca
« on: March 03, 2021, 05:52:39 pm »
Hello all,
I got a "broken" Keithley 2100.
It had error +599 that I solved by replacing the 1000uF capacitors. Now it looks to run fine, Self Test is OK.
I have a question about the DSP. It seems that there is some "bridges" between pins on the ones I have.
Is it normal ? Could you show me picture of your DSP to compare ?
Thx :)
Offline picburner
Re: Keithley 2100 - DSP pin assignment/interconnection
« Reply #1 on: March 03, 2021, 06:32:18 pm »
pins 14 and 15 are both VSS, so there is no problem, for the others I don't know.
Offline picburner
« Reply #2 on: March 04, 2021, 01:40:06 pm »
This pic is taken from here, the instrument is one of the Keithley 2100 clones.
With a little imagination, since the pic is poorly defined, it would seem that the pins are short-circuited here too.
Offline Arca
« Reply #3 on: March 04, 2021, 05:43:14 pm »
Hello,
Thanks a lot for your answer ! :)
So yes you are right, it seems that it's normal.
I admit that I was a little bit stressed because my soldering iron fell inside... 😅
So thank you again !
Offline arturmariojr
  • Country: br
« Reply #4 on: August 04, 2021, 03:19:02 pm »
For Keithley Service Manual, it is the same as Array M3500A. Here you are the service manual.
Best wishes!
Artur
