Author Topic: Keithley 2400 Error Code: 601 Reading Buffer data lost  (Read 10019 times)
Offline JohnPiTopic starter
« on: January 13, 2018, 03:10:07 am »
My 2400 sometimes indicates this error for a second or so on power on; I can't find any documentation about what causes it, or if it is a problem.
Any ideas ?
« Last Edit: January 13, 2018, 05:08:14 am by JohnPi »
Offline Le_Bassiste
Re: Keithley 2400 Error Code: 601 Reading Buffer data lost
« Reply #1 on: January 13, 2018, 09:50:13 am »
nothing serious. check the voltage of the 3V lithium battery that supplies the reading-buffer RAM. its probably dead.
« Last Edit: January 13, 2018, 09:53:33 am by Le_Bassiste »
An assertion ending with a question mark is a brain fart.
« Reply #2 on: January 13, 2018, 06:19:11 pm »
Thanks. It's soldered in with tabs (manual implies it's socketed) -- it's hard to find a replacement nearby...  :(
« Last Edit: January 13, 2018, 07:31:42 pm by JohnPi »
Offline aronake
  • Country: hk
« Reply #3 on: November 02, 2022, 09:42:54 am »
Did you get to replace the battery? Did that solve this problem?
