Author Topic: Agilent 58455A battery  (Read 1123 times)
Offline AiyTopic starter
« on: November 25, 2017, 09:05:31 am »
I'm servicing my oscilloscope and found that the Motherboard CMOS battery is lost. The service manual has a simple drawing of the pc-side motherboard which says its 3V, but not the exact type. Can somebody point to a correct replacement buttoncell ? I tried a cr2032 I had on hand, but the scope didn't want to boot with it.
Best regards
Offline ap
    • ab-precision
Re: Agilent 58455A battery
« Reply #1 on: November 25, 2017, 11:23:16 am »
The battery replacement causes CMOS RAM data to be lost. You need to configure the BIOS. See page 5-16 of service manual.
Keep us posted if you could fix it.
Metrology and test gear and other stuff: www.ab-precision.com
« Reply #2 on: November 27, 2017, 03:39:29 pm »
The CR2032 battery worked after all. I needed to do a reset of the bios with the jumper, then it booted  :palm:
