@PedroDaGr8 Yes, you are right. There must me a short somewhere, but not easy to find. So all the electrolytic caps have been changed, and the rectangular-tantulum ones are tricky to get off, or at least I never did that. So I ended up measuring all the caps while being on the board and most show high resistivity, there are just 2 of the little yellow square caps that show around 220ohms (marked black).
The AC terminals resistance is 1Mohm, the power rails are all in the kohm region, measured on the testpoints. I could just identify one short, where the gate of the triac is shorted with the GND. I dont really understand how this works, but it seems to be shorted via a Thick-Film resistor with 0.15ohms, that was initally burned and changed. I included a picture that hopefully shows that (marked red).
Thanks for helping
