Author Topic: Keithley 2602A repairs  (Read 599 times)
Offline hitecelecTopic starter
  • Country: in
« on: October 24, 2023, 08:05:44 am »
  Hi All
Trying to troubleshoot the subject unit.
unit powers up and doesnt boot   left extreme two segments of display lighting up -- --
 problem appears to be with 5V supply showing 8.5
Trying to locate the SMD cross ref of U136 marked as J96AB SSOP10 package
Also Cr113 and Cr115 showing 20 ohms in cold check. both diodes connected to U136
Any help is welcome. Attached pictures
Thanks in advance
  • Country: in
Re: Keithley 2602A repairs
« Reply #1 on: October 24, 2023, 11:58:03 am »
hello
I found the Device . 5102Sd was written beneath
LM5102SD half bridge driver
Offline 晓看风云
« Reply #2 on: October 25, 2023, 02:35:50 am »
If the short circuit points to u136, you can try using thermal imaging or simply removing it!
