I'm attempting to repair a Toyota engine ECU that it seems has had an over-voltage event, possibly failed alternator or loose battery terminal.
I have found two failed diodes, D401 and D402 (Shorted) marked "1E 8D" which just seem like series diodes from the main power supplies, so have fitted 1N4002s in their place.
However my mystery is D404.
From the screen print, it's a Zener and is directly across the internal supply.
One of its circuit tracks has blown open, so there was obviously more than just a bit of a transient.
The diode is marked: T S5225 8.C
The T I'm assuming signifies Toshiba.
It's in a substantial case 10mm diameter and 4mm thick, similar to a Motorola MR751 series.
Can't find any reference online, it obviously isn't a 1N5225
Logic says the Zener(TVS?) voltage should be in the region of 18 to 24Volts
Any help appreciated
Thanks,
Simon.
