Author Topic: Tektronix TDS7104  (Read 707 times)
Offline YerffoegTopic starter
Tektronix TDS7104
« on: August 10, 2023, 12:11:25 pm »
Looking for some help with a late Tek TDS7104. It died last year while I was using it. The Dallas ram battery finally discharged. So it now hangs trying to load the scope application. I have fitted a new battery module but looking at the debug output it tells me the boot file is corrupt. Nothing new there. However during the boot it gives me a count down from 7 to hit any key to stop auto-boot. Nothing I do will stop the boot process which eventually just cycles round. My RS232 key input goes to the MAX232CPE on the Power PC and comes out of pin 9 on the chip as TTL.  Is there something I am missing. (No not buy a new scope)
Online coromonadalix
Re: Tektronix TDS7104
« Reply #1 on: August 10, 2023, 05:40:53 pm »
you should have searched the forum here before posting
there is some dedicated thread for tds7k series
https://www.eevblog.com/forum/testgear/tek-csa7404-repair-project/
ask a mod to move your thread there ...    :-+
« Reply #2 on: August 10, 2023, 08:59:10 pm »
Thanks. New here. Did not want to use someonelses topic but I can now see you are correct.
Can someone move this to the TDS7K section pls?
