Author Topic: Sony DAT DTC-670, distorted or no playback  (Read 7504 times)
Offline davorinTopic starter
« on: November 08, 2014, 03:47:23 pm »
Good afternoon (o;
I just acquired a Sony DTC-670 which I knew it was defect, but not the ral cause..
Now when I put in a cassette it closes, pulls the tape in, starts rorating the head and soon after stops with a "CLOSE" blinking in the display...
Closing the lid without a tape shows no errors...
Some simple mechanical switch gone wrong?
« Last Edit: November 15, 2014, 06:42:01 pm by davorin »
Offline radhaz
Re: Sony DAT DTC-670, Close blinks in display
« Reply #1 on: November 09, 2014, 11:07:24 pm »
It sounds like a switch problem. Here is a service manual:
http://www.hifiengine.com/manual_library/sony/dtc-670.shtml
Re: Sony DAT DTC-670, distorted or no playback
« Reply #2 on: November 13, 2014, 05:10:44 pm »
Well..the service manual I already have...and only some end consumer type fault messages are included....
Got hold of a second one now...and swapped the drive...after few tries the tape starts playing now....also recordong...
though strange with recordings that now and then some milli seconds are missing...just like a bad CD with lots of scratches...
« Last Edit: November 15, 2014, 06:42:12 pm by davorin »
« Reply #3 on: November 15, 2014, 10:47:59 am »
This is really weired....got it now at that point that it records fine from SPDIF in with audio feed from a Wandboard Linux board...
But when I power off the DAT device and switch it on next day to play back...there is no recording anymore..just the 48kHz is blinking...
« Last Edit: November 15, 2014, 06:42:21 pm by davorin »
« Reply #4 on: November 15, 2014, 04:09:25 pm »
Hmm...happens even with frsh recordings....sound is fine for a few minutes, then distorted (not nice to hear through headphone ;o)...and then okay again...
Now suddenly plays back the Pink Floyd Endless River recording from yesterday (o;
Time to throw away the tapes? I already cleaned the drum head....
Hmm..just discovered that the distortion is not as the same spot when I rewind and play it back again....
« Last Edit: November 15, 2014, 06:42:38 pm by davorin »
« Reply #5 on: November 15, 2014, 06:03:03 pm »
Signal on the drum head seems fine during recording....
« Last Edit: November 15, 2014, 06:42:30 pm by davorin »
« Reply #6 on: November 16, 2014, 10:49:08 am »
Swapped the RF preamp board from another 670 and now it palys back a recording...let's see for how long ;-))
Though it doesn't write the Start ID automatically anymore...
« Reply #7 on: November 16, 2014, 06:37:06 pm »
Hmm...no joy....no playback anymore.....
Even replaced the capacitors on the RF amplifier board as suggested on a Youtube video....
No wonder Ebay is full of Sony DAT recorders marked as broken/for repair....Just never bid for one...you will never get it fixed (o;
Offline Cyberdragon
« Reply #8 on: November 17, 2014, 04:59:27 pm »
Sounds like it could be a loose coil connection inside the read/write head itself causing intermittent failure. Try finding a replacement.
*BZZZZZZAAAAAP*
Voltamort strikes again!
