Author Topic: Kenwood DP-1000 no laser movement, the cog is clicking  (Read 1908 times)
Offline pjasio253Topic starter
« on: March 22, 2024, 07:54:37 pm »
Hello,
After inserting the disc, there is no full TOC reading, but the laser is set to track no. 1 and plays it for up to approx. 20 seconds. An attempt to jump to subsequent tracks causes the laser to return to track no. 1 anyway. During such attempts to "pull" the reading, a quiet knocking noise under the mechanism can still be heard. I managed to observe it and it looks like the circular gear from the laser feed motor encounters "some" resistance and jumps off the teeth of the plastic guide. If I move the gear wheel away for a moment, the laser itself moves along the metal arms of the mechanism without any resistance. I am sending a link to the video, although it is not my own, but it shows the view of the gear wheel and the guide on which this effect occurs.
I would be grateful for any tips.
Offline m k
Re: Kenwood DP-1000 no laser movement, the cog is clicking
« Reply #1 on: March 29, 2024, 02:14:33 pm »
So a mechanical issue of some sort.
Maybe it's just worn out.
Are parts moving also around their supports, like in the video?
If there is a block you should feel it when moving parts manually.
But it can also be present only when angles are a bit off, like in video.
Advance-Aneng-Appa-AVO-Beckman-Danbridge-Data Tech-Fluke-General Radio-H. W. Sullivan-Heathkit-HP-Kaise-Kyoritsu-Leeds & Northrup-Mastech-OR-X-REO-Simpson-Sinclair-Tektronix-Tokyo Rikosha-Topward-Triplett-Tritron-YFE
Offline temperance
« Reply #2 on: March 29, 2024, 04:05:59 pm »
From the video it is clear that the whole mechanism is bending when the thing starts.
Online amyk
« Reply #3 on: March 30, 2024, 01:49:24 am »
Definitely a mechanical problem. The sled should move by gravity if the motor is removed. Might need some lube at the right places.
Offline David_AVD
« Reply #4 on: March 30, 2024, 02:41:48 am »
Carefully inspect all of the gears for damage. I've seen a few Kenwood audio products in recent years where the plastic gears are crumbling.
Offline floobydust
« Reply #5 on: March 30, 2024, 03:30:47 am »
Last time I had the click click click with a CD transport, it was the slide seizing up, it needed lube. Or maybe the worm shaft I forgot.
You can hold the drive gear away and see how it slides, if it binds.
