Author Topic: Microcontroller blown its top off!  (Read 1992 times)
Offline CambridgeMartTopic starter
« on: August 18, 2018, 01:21:23 am »
I have an airconditioner that has packed up; the problem is clearly with the controller board, there's a big hole blown in the top of the microcontroller package! I would guess that the board is beyond repair. Even if I could replace the microcontroller, I don't have the code to reprogram it. In case you're interested, it's an Ariagel TE160, very similar to the DeLonghi PAC400. The replacement boards are unobtanium, so I either need to repair this or somehow come up with an alternative. The unit is a split system, so there's a compressor, 2 fans and a condensate pump to look after, plus the infra red remote control to deal with; how hard can that be?
Offline Rerouter
Re: Microcontroller blown its top off!
« Reply #1 on: August 18, 2018, 01:46:46 am »
Break down the problem and it gets easier, Identify the inputs, (definatly a temp sensor in the indoor unit, possibly some current sensing to the outdoor unit), last one I dealt with had the functional diagram of the outdoor unit under the wiring cover, just had a common nuetral, a wire for the pump, a wire for the fan and a wire for I believe the expansion valve.
Beyond that its like any other electronics project, do the magic between input and output.
Offline coromonadalix
« Reply #2 on: August 18, 2018, 01:51:30 am »
If youre good in any arduino programming, there's some projects flying around, you could create your own processor board
Offline floobydust
« Reply #3 on: August 18, 2018, 04:34:33 am »
MCU with the top blown off is usually a big overcurrent, from a shorted mains triac or failed (capacitive) power supply.
There is an open-souce IR remote-control project of air conditioners using Arduino or ESP8266;
Arduino Midea air conditioner
You would just need temp and fan control code added, to make it a master instead of slave.
Arduino libraries have device control too.
Offline amyk
« Reply #4 on: August 18, 2018, 04:38:48 am »
The MCU in these systems is normally powered by a capacitive dropper, and when the dropper capacitor fails shorted, this is what happens.
At a minimum you could turn the system into manual control by using switches for each of the components (I'm assuming the relays survived, but you should check) --- watch out for mains isolation.
Post a picture (both sides) of the control board if you'd like assistance reverse-engineering it. They're usually only 2-layer and through-hole so not very difficult.
Offline abraxa
  • Sigrok associate
« Reply #5 on: August 18, 2018, 08:11:37 am »
Hmm, is that so? A quick google search found this:
https://www.ereplacementparts.com/delonghi-pac400-portable-air-conditioner-parts-c-122345_122354_122898.html
https://www.ereplacementparts.com/control-board-p-696934.html
https://vdocuments.site/te-160.html shows a really very similar drawing, so just like you said, I'd say one is a rebranded version of the other.
« Reply #6 on: August 18, 2018, 04:38:14 pm »
The controller shown is nothing like the controller in the TE-160, I don't know if they revised the design at some point.
« Reply #7 on: August 18, 2018, 04:41:42 pm »
The Arduino controller sounds like a solution; I have plenty of Arduino projects under my belt already.
The PSU in this is a transformer isolated supply, but a couple of loads are driven by triacs driven via a ULN2004, so a shorted triac could have done the damage; a number of +5V traces were vapourised as well, so a large current has definitely flowed through the 5V rail at some point.
Offline Mr. Scram
  • Display aficionado
« Reply #8 on: August 18, 2018, 04:46:23 pm »
What caused the microprocessor failure? Replacing it is no use without fixing that first.
« Reply #9 on: August 18, 2018, 04:48:55 pm »
Both triacs measure <200 Ohms between MT1 and gate, so that could well be the reason.
