Hello everyone! Ok, quick back story - I'm trying to learn electronics better because they interest and intrigue me. I've been watching Dave's videos for years, as well as Mr Carlson's lab, Radio Repair Shop and others on YouTube. I picked up an amateur radio license for VHF/UHF, but didn't find a whole lot of use in my area, so I picked up a general class license to get on the HF airwaves. My main goal for doing that was to better learn electronics, so what better way to force myself to learn than to pick up a radio that needed some work! (Yes, I'm a sucker for self imposed punishment lol) So, I have on the healing bench a Kenwood TS-430. I went with this radio as it's 80's tech using lots of easy to work on through-hole components, relatively simple circuits, easy to find service manual/schematics, and lacked the corrosive goop that other models had utilized.
So, The radio powers up in that it has static on the speaker, you can hear the relays click up and down the band, switch modes, but there's no display for frequency output, and no receive. So my first guess is something's wrong with the PLL circuit..
But that's not where we start, so first things first - check voltages. They're all checking in range, so I move to step 2 in the service manual, which is checking the frequency of the primary oscillator. This is supposed to read 36Mhz. I hook up my frequency counter using a BNC to aligator clip lead, ground the negative and clip on the positive - nothing. So I switch my frequency count out for my signal generator which can also count, and I get the same deal, so I assume there's an issue with the oscillator circuit, but since I've got the gear, I figured I'd hook the oscilloscope up, and I got the same reading grounding the probe ground to chassis and reading the frequency. So this seems like a fairly simple solution, likely a bad crystal perhaps... but I'm also a noob at this, so maybe I'm trying to measure this oscillator wrong
I did notice that if I left the ground from the BNC to alligator clips off, or the oscilloscope probe ground off, I'd get a measurement varying from 82 - 111 Hz, but I am suspect that in this instance the lead is acting like an antenna picking up some other interference perhaps, but it was rather consistent amplitude, which doesn't sound like noise lol
So, I tried swapping the crystal out for a new 36Mhz crystal. No change. So my next though was "Well perhaps another part of this circuit is dragging down the output", so I figured the next approach would be to try to isolate the crystal oscillator to itself from the rest of the circuits, so I pulled Q6 out, as well as C38 (though maybe this is needed for the oscillator to work? I'm doing this to learn oscillators and RF stuff better. The voltages on Q6 were pretty close to indicated). There's 6v feeding R24, which along with R25 forms a voltage divider that feeds just over 4v to the left side of the crystal, and those resistors are both within spec. So my understanding is that with the voltage applied to the crystal it'll self oscillate, and the reference to ground being through the parallel inductor/resistor through C36 and the trimmer capacitor that allows you to adjust the frequency (capacitive coupled to ground??). At any rate, testing with the oscilloscope on either side of the crystal shows 0 oscillation with the scope's probe grounded with Q6 and C38 removed. Did I remove components vital to the oscillator working? Should I be testing a bit further downstream by removing Q7? I'm I not measuring for oscillation correctly? Is this indicative of the 1uhenry inductor being bad?
I sort of get the feeling that Q6 and C38 form part of the needed "feedback" for the oscillator to work, so perhaps I should pull C40 and then measure for frequency at the Q6 emitter? This is where I start to lose understanding of how things are working and it starts to turn into "black magic" haha
I assume Q7 and Q9 are essentially acting as "amplifiers" to drive down stream circuits. This primary oscillator is used to drive many other parts of the radio, including the PLL circuit that drives the display and controls tuning etc.. The official test point for measuring for 36Mhz is at connector 1 at the bottom of the supplied schematic image.
Thanks for any help or understanding anyone can provide on this!
Chris
