Author Topic: Keypad replacement  (Read 243 times)
Offline PlainNameTopic starter
  • Country: va
Keypad replacement
« on: October 28, 2024, 02:28:03 pm »
Got a keypad (mentioned elsewhere) with domed buttons. An official replacement is both unobtanium and expensive, so I am looking at a DIY solution.
What I have in mind is a flex PCB, which JLCPCB would do for next to nothing (unless I add a stiffener, and then it gets uncheap. But what about the buttons? Perhaps a tactile switch would suit, but there are so many it is hard to know what to look for or which might be appropriate.
Any suggestions?
Offline Koray
  • Country: tr
Re: Keypad replacement
« Reply #1 on: October 28, 2024, 02:52:10 pm »
Your holiness,
Replacement cross-shaped domed switches are available on aliexpress:
https://www.aliexpress.com/item/1005004544751246.html
K.
« Last Edit: October 28, 2024, 02:54:18 pm by Koray »
  • Country: va
« Reply #2 on: October 28, 2024, 03:01:19 pm »
Thanks, but the switches themselves are fine - it's the tracking that is borked. With a replacement tracking layer, I'm not sure those switches are the right solution (specifically, difficulty in mounting on a flex PCB).
« Last Edit: October 28, 2024, 03:05:02 pm by PlainName »
