Hi, and thank you for this post. I was not a member of this group, but have now joined.
I have had a Vita R1 for a long time and last month it gave up the ghost. Every time I powered-on it burped a few times and then gave up. I have been so in love with this radio I decided to look for any possible causes before throwing it out. I found your post and read with great interest.
As a result, I purchased a TDA7266 from e-bay. I also found what I thought were two leaky capacitors (470uF and 4700uF) and ordered some of those as well (sadly I couldn't order one of each, so now have 9 spares of each if anyone is in need). Whilst having worked in the TV trade many years ago, and then computing, I was lost with regard to signal checks and the like you were undertaking, but felt reasonably confident to replace the chip and caps.
30 mins later we were all done and the Radio is back in use. Thank you.
I now need to look at doing something about the display, this gave up some years back but maybe there is something reasonable I can undertake in this regard.
Thanks again.
