so it seems I fixed it, it sounds obsurdly bright but still has plenty of power to play some BASS trough it.
I'm gonna remessure all the voltages now and post them.
also the base of VT9 is 9V cause the supple is 9.6V. 9.7V when I replaced nearly all of the leaking (in both ways) electrolitics.
I now am trying to figure out all the wiring to the volume/tembre control and nearly figured it out.
I also got no output at all when touching the casette player head wires so it would induce some 50hz hum in it. but nothing, but I will probably make a diffrent post about that since this one is already full of comments about the power amp.
EDIT: the uni-t meter was like 25eur was the best meter I could find for when I just started working on electronics, I know that I should get a new meter probably cause this one is pretty inpresise, only thing good about it is that it doesn't care if you pump 1kv in to it when working on tube radios
. and yes I know it's dangerous to do that but I'll make sure not to touch it.
if you want the model for it it's a UT20B
