Author Topic: Keysight 34410A doesn't boot up  (Read 703 times)
Offline dophucTopic starter
  • Country: vn
« on: January 02, 2025, 03:07:13 am »
Hi everyone,
A few days ago my 34410A was working fine, yesterday it suddenly couldn't start. When pressing the power button it gets stuck on the display (all characters appear) and there is no warning sound. I have no experience repairing similar equipment so I don't know where to start checking. Thank you very much for the information about this error as well as replacement parts.
« Last Edit: January 02, 2025, 05:10:45 am by dophuc »
Offline coromonadalix
Re: Keysight 34410A doesn't boot up
« Reply #1 on: January 02, 2025, 04:21:14 am »
is there a stuck button .... looks like its held in a reset state,   like an  vfd test
the schematics for theses can be found on the web
http://www.ko4bb.com/getsimple/index.php?id=manuals
type 34410a  in search,   2 links should appear
« Last Edit: January 02, 2025, 04:24:10 am by coromonadalix »
The following users thanked this post: dophuc
  • Country: vn
« Reply #2 on: January 04, 2025, 01:40:25 pm »
Thanks for the reply, I took the device apart to make sure the button wasn't stuck. Check the voltage levels of the output power from the transformer, there are no problems.
Since it can't boot, I'm speculating it could be a problem with the memory, ram or processor... not sure because there's no way to check.
« Reply #3 on: January 04, 2025, 05:15:14 pm »
i would say   check all supply lines,  and you have isolated ones too,  check if you have all the crystal clocks running ....  maybe just maybe  a tantalum shorted out ?
i don't know if you have a logic probe    you could poke on the front panel connector if you see  the 3.3v 12v    reset line if stuck,  data in  out line, and for sure  the filament voltages
you have to check all section one after the other,  mostly voltages 1st,  you have isolated +18 -18 volts lines and a 5 volt  for the analog section or redacted out,   some open office tool was able to recover it,   i put 2 files here
other link for the schematic  https://www.dcddcc.com/blog/34410a/schematic.34410a.pdf  it miss the supply section
and lastly  you dont change parts for nothing hoping it will work, i dont know your expertise levels
« Last Edit: January 04, 2025, 05:29:14 pm by coromonadalix »
  • Country: vn
« Reply #4 on: January 05, 2025, 03:41:50 am »
I found a video a long time ago on YouTube, a person who bought a new 34410A had the same situation as me. He sent it back to the company and they replaced it with a new one and the engineer could not determine the error. Mine was not so lucky as it was no longer under warranty.
https://youtu.be/PKW75jDLB_U?si=Orew3ssb0C_gkpvS
Offline bsw_m
  • Country: by
« Reply #5 on: January 05, 2025, 05:49:32 am »
The following users thanked this post: Mickle T.
Offline Swake
« Reply #6 on: January 05, 2025, 08:21:50 am »
In the video at about 0:25 you can hear a relay clicking right after he cycles power. And again at 0:54 after a second power cycle, but that one is difficult to hear as he makes a lot of noise.
Is yours doing the same?
Would this indicate that the issue rather be in the display board than in the main board?
Is the mainboard alive?
- Connect to usb/ ethernet and see if it responding.
- Scope the data lines on the mainboard and between the 2 boards and see if it is alive.
- Try measuring something and see if that changes the relays.
When it fits stop using the hammer
« Reply #7 on: January 05, 2025, 03:38:26 pm »
you could try to install the old keysight io librairies   16 or 17 i think   and  the old  dmm utility  not the bench vue
or this  34410a  is supposed to accept 34401a commands,  never tried
https://github.com/Niravk1997/HP-Agilent-Keysight-34401A-Control-and-Data-Logging-Software
or even this excel sheet i made to control my 34410a at some point,  need to enable macros etc ...  in usb   but you  need at least  Rhode Schwartz visa drivers, and they include tools in them to send direct commands or use the excel sheet ?
« Last Edit: January 05, 2025, 03:45:15 pm by coromonadalix »
Online the Chris
« Reply #8 on: January 05, 2025, 07:18:27 pm »
As suggested by bsw_m, it might be the SRAM chip. I got an E3631A power supply with a similar symptom and found a thread with others that were experiencing the same. I could fix it the same way as all others did by replacing the SRAM, see https://www.eevblog.com/forum/repair/hp-e3631a-triple-output-power-supply/msg5724953/#msg5724953
The following users thanked this post: Mickle T., bsw_m
