Hi guys, sorry it took some time to reply back.
Thanks 2N2222A - Indeed we need to look carefully at the positive traces. I did some testing with another multimeter and they seem ok, but I'll re-check with a small microscope that I have.
I'll summarize everything we got until now since this will make it easier for other forum members to get the values if they need:
The markings on my PCB are as follows:
- U1233-26500
- REV00Z (it could be 007. It is hard to read the last character since the fuse holder is soldered on top of it)
- MSS-B white sticker
C50, C98 and C99I guess whe're all on the same page these are 100uF 16V SMD Aluminum Electrolytic Capacitors.
Mine are marked as 275-100-16E so I believe the 245-275 is the date code. I'm just unsure about the E marking if this means anything special about it.
C52Missing
C5926µF
C6027µF
C619µF
C62176nF
C6825µF
C6916µF
C206Mine is intact. Will have to remove it to measure. Stay tuned...
C207Mine is intact. Will have to remove it to measure. Stay tuned...
CR18Still missing.
CR22I did some research and the marking I have is "PD>" - This seems to be a BSS84L MOSFET
https://www.onsemi.com/download/data-sheet/pdf/bss84lt1-d.pdfAlthough I'm pretty confident this is our guy and the tiny dot we see on the marking indicates it is a pb-free package, I couldn't find any datasheet that covers the > marking. It seems to me that it can be only the date code though.
R3, R4, R5, R6 and R7They all measured 2M ohm. Since they're in series, total series resitance is 10M ohm so this confirms 2M each.
The color coding is red-black-black-yellow-brown so they have a 1% tollerance.
Cheers
