I recently received a Maury A027A SMA gage kit. Unfortunately, the gage mating surfaces did not have protective caps over them and the foam apparently degraded, leaving residue on the mating surfaces. The foam was replaced when I received it, but the residue is still there. I would expect the foam material is polyurethane, which is a common choice for these sorts of things and degrades over time. However, I can't be sure.
Any recommendations as to how to clean this? I've attached an image showing the mating surface of one gage. This is one of the worst ones, but the rest are similar. Normally, I'd use a fine-tip q-tip with some IPA. But, I'm not sure that's small enough and I'm also not sure it will remove residue that's probably gotten into the space between the sliding mechanisms. I've also thought about standing it upright (mating surface down) and soaking the end in some sort of solvent. I could try IPA, though it may not be effective enough. Another option is naphtha, which I believe should be effective on the residue and safe on the metal surfaces. I wouldn't want that to get residue further up into the sliding mechanism. Or, having the naphtha remain in those tight spaces. Are those risks? Thoughts on this solution? Other thoughts?
I tried blowing it out with an air compressor, but the substance is too sticky and won't budge.
If it's not easy to clean, I can return this for a refund. But, if I mess it up, I'll lose that right. So, I'd prefer not to try anything that is unlikely to work or could cause damage.
