I have a Beckman Industrial 5060 which is a rebranded kikusui 5060A that is experiencing a weird variety of problems.
The unit powers up, gives trace, but the screen despite being bright requires the intensity set all the way up - back it off a MM and it goes black. It also varies when playing with the timebase and if I play with the trace source, there is a specific combination (I believe AC source/Ext and Ch1/Add) that will make the display very bright. It's also giving me half-faded trace, half trace missing (fades off for no apparent reason, change the volt/div and it comes back, change again and it starts moving, change back and it holds still, chaos), pushing controls sometimes makes it sputter/glitch.
Before I go and recap the PSU, I thought I would post here and see if anyone else has a Kikusui 5060 and has any schematics or ideally a service manual - I have been unable to find one online.
Any help is much appreciated and thank you in advance.
Edit: For future searchers who may find this thread who have one of these fairly rare scopes, I thought I would post the issues mine had and repairs I made.
1. Fuse holder corrosion on back side leading to poor contact and all manner of intermittant voltage related issues manifesting in random glitching, trace blurring, etc Fix: removed fuse holder, cleaned with dremel internally and replaced with proper fuse - the unit will not run correctly unless set appropriately, this is universal but some ppl dont know this.
2. Pot dirtiness - the pots on the unit needed a thorough cleaning with deoxit, I additionally cleaned with naptha based lighter fluid and small wire brush on all contact pins to ensure continuity.
3. All 3 filter caps were out of value and leaky manifesting in even more power issues. 2200uf/1000uf/47uf voltages on fuses ranging from 50v up to 200v on the 47v fuse. Fuses are AC connected off of pin 3 - 4 (I believe) of the transformer pre-rectification. I chose to replace the 47uf/200v fuse with a pair of 400v 100uf fuses and build a small pair of legs to accommodate. I did not put a balance resistor on either cap b/c this is coming off of AC, this is not the best practice, but, I did it anyway and its working fine.
There are very few resources online for these scopes, feel free to message me here I will do my best to help.
