Author Topic: Speed control for AC fan  (Read 1425 times)
Offline BryanTopic starter
« on: December 18, 2020, 05:04:01 am »
All:
Does anyone know what type of AC motors these types of fans use. I doubt a light dimmer would work to control the speed and one has to vary the frequency. Motor speed controller etc.
-=Bryan=-
Offline amyk
Re: Speed control for AC fan
« Reply #1 on: December 18, 2020, 08:07:37 am »
Likely some sort of induction motor - depending on power output, could be shaded pole (lowest power), split-phase, capacitor start, or permanent split capacitor, among others. Without changing the frequency, limited speed control is possible by varying the voltage. Otherwise it is as you say, a VFD will be necessary.
« Reply #2 on: December 18, 2020, 05:46:07 pm »
There is a controller on the line cord but it only varies the fan speed by maybe 10%, I didn't want to crack the case to void the warranty, might do it anyway to see what it is doing, suspect just a pot and a cap.
-=Bryan=-
Offline pbarton
« Reply #3 on: December 18, 2020, 10:15:04 pm »
Same fan with a speed controller....
https://www.amazon.com/VIVOSUN-Inline-Ventilation-Variable-Controller/dp/B01CTM0JF2/ref=sr_1_17?_encoding=UTF8&c=ts&dchild=1&keywords=Household+Ventilation+Fans&qid=1608330416&s=hi&sr=1-17&ts_id=5446824011
Depends if the AC motor has one winding (two leads), or two winding's (3 or 4 leads).
There are several AC motor speed control circuits if you Google “ceiling fan speed controller”.
Strange, the Amazon listing fails to mention that its 110V and 60Hz.
« Last Edit: December 18, 2020, 11:29:55 pm by pbarton »
« Reply #4 on: December 19, 2020, 09:21:35 am »
Exact same fan I have. Did a bit of disassembly. Controller uses a Triac (BT138), will try and draw the schematic out from the PCB. I think with different values, potentiometer... maybe one could lower the speed further.
-=Bryan=-
Offline Ed.Kloonk
  • Cat video aficionado
« Reply #5 on: December 19, 2020, 11:24:11 am »
Fine looking soldering job on the black wire there.
iratus parum formica
« Reply #6 on: December 19, 2020, 11:41:57 am »
Lol, true on that.  The one on the output side of the line is worse.:)
-=Bryan=-
Offline NiHaoMike
    • Facebook Page
« Reply #7 on: December 19, 2020, 05:38:22 pm »
At that price, might as well just get a 120mm Delta server fan, print some adapters to mate it to a 6" duct, and build a simple 555 circuit to vary the speed. It would be way more efficient, similar or lower total cost after adding all the parts, and the speed control will actually work over a good range.
