Hi guys, I wanted to ask anybody with experience on capacitive touchscreens about this:
Before trying anything, I wanted to ask you if you have had an experience with capacitive touchscreens that do not respond, and specifically, the case of the Kindle Fire 1st generation.
More than a year ago this Kindle started to develop a problem in which it registered touch events when there weren't any. Sometimes I would touch the center of the screen and also get input on the corner of the screen, for example. After this, it began to miss touches in a section of the screen. Eventually, one day it decided not to get any input at all. When I bought it it was always a bit too sensitive.
So I charged up the battery to roughly 50% and stored the thing for a long while. Now I kind of want to use it again. I have tried plugging and unplugging the touchscreen flex, I disassembled the Kindle to inspect the touchscreen digitizer and nothing looks obviously wrong. The flex cable has a chip soldered on board as well as some other passives and a couple of sot23 packages. I tried putting some pressure on those just to see if the problem was solder joints, but nothing.
I kiiinda got it working for a fraction of a second making a lot of pressure on one section of the digitizer, with the Kindle assembled, but I can't replicate that.
I tried putting it in a dry, cold environment. No change. Before that, I tried heating the digitizer a bit with a hair blower, nothing either.
A new digitizer is $17, and perhaps I could buy one.
