Author Topic: Mackie Onyx 1620 Psu fault  (Read 3834 times)
Offline miksepultTopic starter
  • Country: no
« on: June 11, 2018, 12:02:04 pm »
Hi! I have a Mackie Onyx 1620 mixer which is not working correctly. I have narrowed it down to the PSU. The lights are flashing, and you can hear a clicking noise (about 1 time per second. I've changed all of the electrolytic capacitors, that helped, but it still didn't work. (It helped a bit).  I started mesuaring voltages, and when I tried to mesure one of the diodes (think it was D2), it made a spark and suddently stopped working.  |O Do you think that you could help me to figure out what's wrong? :) (Look at the schematic and video below)
Regards Benjamin
« Last Edit: June 11, 2018, 12:26:14 pm by miksepult »
Offline xavier60
Re: Mackie Onyx 1620 Psu fault
« Reply #1 on: June 11, 2018, 11:02:21 pm »
Check  all of the outputs for any pulsing voltage. If there is, then the power supply isn't totally dead and you might now have a shorted output diode as well as the original fault which possibly involved the 15V Bias supply.
Are you using an isolation transformer? What other test equipment do you have?
Don't power it up with anything removed that will break the regulation loop.
« Last Edit: June 12, 2018, 12:52:29 pm by xavier60 »
HP 54645A dso, Fluke 87V dmm,  Agilent U8002A psu,  FY6600 function gen,  Brymen BM857S, HAKKO FM-204, New! HAKKO FX-971.
  • Country: no
« Reply #2 on: June 12, 2018, 12:01:53 pm »
Check the all of the outputs for any pulsing voltage. If there is, then the power supply isn't totally dead and you might now have a shorted output diode as well as the original fault which possibly involved the 15V Bias supply.
Ok, thanks! There isn't any voltage at the outputs, but the voltage reaches the transformer. I don't now if it's an isolation transformer. I have just a digital multimeter. (UNI-T UT132E)
Regards
Benjamin
« Last Edit: June 12, 2018, 12:03:25 pm by miksepult »
  • Country: no
« Reply #3 on: June 12, 2018, 12:06:46 pm »
Here are some pictures:
  • Country: no
« Reply #4 on: June 12, 2018, 12:07:33 pm »
Some more:
Offline xavier60
« Reply #5 on: June 12, 2018, 01:30:47 pm »
Did you check for shorted output diodes?
T1 is an isolating transformer.
« Last Edit: June 12, 2018, 01:32:46 pm by xavier60 »
  • Country: no
« Reply #6 on: June 12, 2018, 01:40:51 pm »
Ok. I've tried to mesuare the diodes. Some of them passed voltage through the wrong way. Mesuared with the diode function on the multimeter. Was like 1k from positive to negative, and 200 from negative to positive.
Offline xavier60
« Reply #7 on: June 12, 2018, 02:01:08 pm »
It's normal for schottky diodes to measure a low forward bias voltage. The 1K reading could be because of resistors in circuit.
Shorted diodes usually measure less than 1 ohm.
    U1, TOP249 is suspect. Check all nearby resistors before replacing U1.
  • Country: no
« Reply #8 on: June 12, 2018, 02:25:55 pm »
Ok, thanks! Is it possible that i have destroyed the top249 when i tried to mesuare the diode? I've ordered a top249, so I'll see if that fixes it. 🙂
Offline xavier60
« Reply #9 on: June 12, 2018, 02:36:22 pm »
Yes, it's possible, not for certain. Also check D16 and R42.
It is also possible for the opto-coupler, U3 to be responsible for the original problem.
The following users thanked this post: miksepult
Offline xavier60
« Reply #10 on: June 12, 2018, 02:43:02 pm »
Be certain that it is the TOP249Y to get the correct package type.
  • Country: no
« Reply #11 on: June 12, 2018, 02:44:23 pm »
I'll check that! 🙂
Will come back with some more info when I've changed the top249 🙂
  • Country: no
« Reply #12 on: June 12, 2018, 02:45:12 pm »
Yes, I ordered the top249y.
Offline shakalnokturn
« Reply #13 on: June 12, 2018, 10:06:08 pm »
R23 is cooked, possibly because you slipped making measurements, it is likely to have caused other damage.
I'd be checking/replacing:
D2, D3, D7, D8, D9, D11, R20, R21, R22, R23, U3, U1.
For the starting point problem check:
C55, D16, R42, R1 to R9.
Also just because they have run hot check solders on R26 to R35.
Offline xavier60
« Reply #14 on: June 12, 2018, 10:54:44 pm »
D7,R20,R21,R22,R23,D8 and the opto-coupler form the output voltage sensing part of the regulation loop.
Although the TOP249Y has a protection feature that will cause it to not run continuously with an open regulation loop, it's still possible for it to be damaged by over voltage pulses on the Drain pin.
Because opto-couplers can't be easily tested, it must be replaced also.
