Hello.
I'm looking for known-good measurements or photos of some passives of the primary side PSU of the Presonus Eris 3.5 studio monitors.
Board version is v1.2 (2018-05-04).
I've already looked for typical application circuits in datasheets and application notes and some come quiet close, but do not 100% match:
https://www.st.com/resource/en/application_note/an246-uc3842-provides-lowcost-current-mode-control-stmicroelectronics.pdf (pg. 19, closest, non-100% match, no optocoupler)
https://www.ti.com/lit/an/slua143/slua143.pdf (pg. 13) (good, no 100% match)
Specifically I'm interested in:- R49
- C without designator below R49
- C10 or C19 (hard to read, below R51)
- R54
- R60
- R1, R61 (1210 in parallel)
Diagnosis:- No char marks elsewhere except around the PSU controller.
- Switching transistor Q3 shorted between drain and source
- Components in the switching transistor path blown
- UC3842B shorted across multiple nodes
- F1 did it's job
- The NTC is OK
- Switched transformer winding ~200mOhm (sounds legit)
Blown or bad measured components are marked with a red "x" in the partial, reverse-engineered schematic:
(No guarantee that the schematic is 100% correct. U3 in the schematic is supposed to be U8.)
Damaged area details:
U8 marking:
PSU bottom overview:
Teardown guidance: - Remove all back plate screws
- Unplug the cables
- Discharge and check primary side caps (i.e. using Low-Z) or handle very carefully
- Pull the knobs off and remove all screws to the connectors and stand-offs
- Use a spudger to carefully lift the glued foam from the backplate around the connectors
Raw measurements from my notes:- NTC (undesignated, next to CN1) = 3.2Ohm
- F1 = open
- Q3 = TSF 10N60M
- open on pins 1 and 2 / 1 and 3 (gate vs. source/drain)
- shorted in both directions on pins 2 and 3 (source and drain)
- U3 = UC3842B
- Ground vs. Isense vs. Vin shorted
- R61 = 191k
- R1 = 180k
- R61 || R1
- R54 = 570k [with U3 removed]
- C19 (C10) = 1.9k, capacitance not measurable, 34k [with U3 removed]
- R51 = 9.4k, [also with U3 removed]
- R49 = 17.9M, open with [with U3 removed]
- Cx (undesignated, below R49) = open
- R28 = 20k
- C9 = capacitance not measurable
- C58 = capacitance not measurable
- R32 = 2k
- C59 = capacitance not measurable
- R31 = 14.9k
- R60 = 6.5k
- R36 = 19.8k
- C57 = 26µF
- R102 = 560k [with U3 removed]
Thank you in advance.
