Hello everyone,
I am a new member on the forum and first of all I greet you all nicely.
I recently purchased a KORAD 3005D PS. Right from the start, I had a bad feeling when I noticed a broken green earth connector. Not the worst case, but a more serious problem is that despite the calibration, the display shows 50mA less output current than it really is. It is NOT range dependent, if I set the max current to 50mA, the output is exactly 50mA, but the display shows 0mA. So even when I set the max current to 1A, the output is 1.003A, but the display shows 952mA. The same story is at 5A.
Reading the forum I found all the schematics. A detailed inspection of the board showed nothing special, however I resoldered the pins on the operational amplifiers (TL082), but there is no change. I don' t know if I understand the schematics, but I think that AD1 and AD2 are the analog inputs to the mPC to somehow display the "set" value and the measured value of the current ? Not sure, but I rather repair that and learn something, than communicate with sales on Aliexpress for returning and spend money for shipping.
Any help or hints are very welcome
