Need a little advice.
My KD3005D has a failed 12V fan power feed.
Got around that by adding a 7812 TO220 Vreg to drive the fan, off the auxiliary xformer winding that feeds the PCB via the 3 pin J3. Fan draws about 180mA.
However, my unit can only do 1.5A continuous (a 12V 35W automotive incandescent lamp used as a test load). The problem predates the fan fix.
Once it crosses 2.2A it will totally freak out and start click cycling the relays continuously on a 1 second time base or so with resultant current/voltage spiking.
Any suggestions where to approach this given I don't have a schematic, unless the one posted here is up to date for the KD3005D. I have a decent workshop....Several O' scopes (Tektronix Analog & Digital up to 4GHz), Bench 6.5 digit DMMs , handheld Fluke DMMs, Spectrum analyzer, HP Vector NA, 3Ghz Agilent NF analyzer, Function gens, Capacitor & ESR testers, curve tracers...assorted other vintage Tektronix gear/plugins and 44 years of electronics experience and prod. dev. M.I.T. certified.
I could try to reverse engineer the control system for the 2 NPN power output transistors, but time is a bit tight. They are in full parallel configuration and this is not a switching PSU. Linear tracking with a beefy transformer running fed by 120VAC 60Hz.
So...since this thread seems the mot detailed in so far as circuit function...I am asking for some precision pointers. Thx!!
