I had been using my Korad for a few weeks when I realized that the fan never seemed to run. I listened in the back and it was making a odd humming sound.
So I took the unit apart and fed the fan voltage directly from a power supply and it worked fine. Then I metered the board output to the fan and it gave a reasonable voltage that should run the fan.
Confused, I hooked the fan back up to the board and measured the voltage the board produced under load. This time the board failed to produce nearly enough voltage to power the fan and the fan made that same sad humming sound.
Here is an album with various pictures of the PCB and descriptions from my testing
https://imgur.com/a/xNmjzks.
Any ideas what I should be looking for to fix?
