It's used as a VCF isn't it? VI would be the frequency control voltage.
A quick bit of digging found this. "The Korg 35 is a masterpiece of simplicity. Inside the chip there are five transistors and six resistors. By adding a small number of external components around the Korg 35 it can be configured as a high pass or low pass music filter. There is one in the MS-10 configured as low pass and the MS-20 adds a second Korg 35 for it’s high pass function. Thus was born the distinctive and quite aggressive Korg filter sound.The Korg 35 is a form of Sallen Key filter that uses clever transistor biasing to enable the filter to become voltage controllable. Later MS-20’s for some reason discarded the 35 module and replaced it with a chip-based OTA transconductance filter."https://secretlifeofsynthesizers.com/the-korg-35-filter/So I would surmise that V1 is a voltage input to control the filter point. I'd assume Vin is the audio signal. I may be wrong though.
You can find the service manual for the MS-10 synth on the web easily and study the circuit.
