Author Topic: Korg Electribe ER-1 mkII repair  (Read 5261 times)
Offline feedback.loopTopic starter
« on: September 09, 2019, 12:38:17 am »
This Korg ER-1 had a burned 5V DC-DC converter, which, most probably, killed some other important parts such as the micro-controller, DSP and memory. The DC-DC converter was repaired, but there were no signs of life, and the DSP seems to run too hot. At the moment this looks beyond economical repair.
« Last Edit: September 24, 2019, 04:47:33 am by feedback.loop »
The following users thanked this post: Falkra, frozenfrogz
Offline Ordinaryman1971
Re: Korg Electribe ER-1 repair
« Reply #1 on: September 09, 2019, 04:55:04 pm »
Did you price the DSP replacement? Any availability?
« Reply #2 on: September 09, 2019, 08:41:48 pm »
I see some on AliExpress for $25-30.
I am afraid that having no copy of firmware, it does not make much sense to order expensive parts.
Offline LateLesley
  • Country: scotland
« Reply #3 on: September 09, 2019, 11:47:11 pm »
What about if you could get firmware? It's not free though, and might make it too pricey still.
http://electribe.cc/wp/about/
The following users thanked this post: Mr. Scram
« Reply #4 on: September 10, 2019, 02:06:21 am »
First of all, this is an update to load through MIDI assuming a working machine with some sort of a boot loader in it at least. I need an image of the flash memory, which is not the same.
The following users thanked this post: LateLesley
Re: Korg Electribe ER-1 mkII repair
« Reply #5 on: September 24, 2019, 04:54:52 am »
Got myself a TSOP48 adapter for TL866 programmer.
It was a part of a $22 set.
To be continued...
« Reply #6 on: September 29, 2019, 05:49:35 am »
Desoldered the flash. It is alive! Now I think it makes sense to proceed. I will order replacement MCU and DSP.
Offline LateLesley
  • Country: scotland
« Reply #7 on: September 29, 2019, 02:34:16 pm »
Awesome! Good luck with the repair. Look forward to updates. :)
Offline james_s
« Reply #8 on: September 29, 2019, 05:16:34 pm »
I've fixed a couple of these that thankfully were less severely damaged. In both cases I'm fairly certain someone plugged in a power adapter of the wrong polarity. For reasons I've never been sure of, music gear seems to almost all use the weird center-negative power adapters while 99% of everything else is center positive. People assume that if the plug fits that it's ok to use which in this case obviously it is not.
« Reply #9 on: September 29, 2019, 08:53:09 pm »
No, wrong polarity cannot kill this thing. There is a very simple and effective protection - a diode right after the power connector. It drops a few hundred millivolts, but who cares.
However, a higher voltage can kill it. Say, above 16V can be fatal for this DC-DC converter chip.
Offline james_s
« Reply #10 on: September 29, 2019, 11:40:51 pm »
I wonder if they revised it and added a diode? Or maybe they were a different model, but I know they were Korg Electribe devices. Pretty sure the ones I fixed didn't have a protection diode but perhaps they did and it was overvoltage that zapped them.
« Reply #11 on: November 02, 2019, 08:01:19 pm »
It works!
The firmware is attached.
The following users thanked this post: Falkra, LateLesley
Offline james_s
« Reply #12 on: November 02, 2019, 09:13:27 pm »
Awesome! Nice job!
So it turned out to be the MCU and DSP?
« Reply #13 on: November 02, 2019, 09:16:58 pm »
DSP and at least one of the memory chips, maybe both, and maybe MCU as well, but it is not clear.
« Reply #14 on: November 03, 2019, 07:52:04 pm »
A couple of red LEDs on the front panel have lenses broken off. These seem to be Panasonic LN282RPX, which are obsolete.
https://www.digikey.com/product-detail/en/panasonic-electronic-components/LN282RPX/P547-ND/410764
Any ideas where to get them?
Thanks.
Offline fzabkar
« Reply #15 on: November 03, 2019, 10:12:44 pm »
Did you get hold of the firmware update package? FWIW, I wrote a tool to convert Roland's 7-bit MIDI formatted firmware binaries to 8-bit flash BINs. Perhaps Korg's format is similar?
Offline Whales
    • Halestrom
« Reply #16 on: November 03, 2019, 10:46:29 pm »
Aww, those LEDs are cute.
Do you need anything more than the cylindrical end?  Would a thin 3mm LED held a bit taller do?
Unfortunately this will give you a different brightness and possibly a different colour tint.  It might be worth considering the option re-LEDding the whole board, as distasteful as that might sound.
Offline LateLesley
  • Country: scotland
« Reply #17 on: November 03, 2019, 11:25:26 pm »
Any chance you could use ones of a similar 2mm form factor? These don't seem quite as long I don't think, but might do the job?
https://www.ebay.co.uk/sch/i.html?_osacat=0&_odkw=2mm+led+round&_from=R40&_trksid=m570.l1313&_nkw=2mm+led+round+red&_sacat=0
EDIT : I found these, which are 8.0mm high, instead of 7.9mm?? https://www.digikey.com/products/en/optoelectronics/led-indication-discrete/105?k=&pkeyword=&sv=0&pv966=282200&sf=1&FV=37%7C395219%2C-8%7C105%2C525%7C395219%2C2029%7C122870&quantity=&ColumnSort=0&page=1&pageSize=25
But I see their mcd rating is a lot larger....
How about these? A little shorter at 6mm and dimmer, but closer to the original specs? https://www.digikey.com/product-detail/en/lite-on-inc/LTL-1214A/LTL-1214A-ND/3198382
« Last Edit: November 03, 2019, 11:34:14 pm by LateLesley »
« Reply #18 on: November 06, 2019, 04:49:57 am »
Thanks for suggestions. I have seen the ones with flat top. I would think they should fit, but they will look different and probably will have different color and brightness. Should be fine if all are replaced - 17 red and 5 green ones.
I still hope to find Panasonic ones.
« Reply #19 on: November 06, 2019, 04:51:26 am »
I am not sure what are you talking about. What problem are you trying to solve?
Offline LateLesley
  • Country: scotland
« Reply #20 on: November 06, 2019, 07:03:58 am »
Ok, I did a bit of googling. I found this place which says they have stock.
https://ph.infinite-electronic.hk/product/Panasonic_LN282RPX.aspx
https://www.components-store.com/product/Panasonic/LN282RPX.html
I found several similar links, it seems all roads lead to HK for stock.
« Reply #21 on: November 09, 2019, 03:19:53 am »
I do not know these sites. They might be fraudulent.
http://www.erai.com/ERAI_Blog/3153/__Fraud_Alert__High_Risk_Websites_That_Take_Your_Money_and_Run_
They are not in this list, but have very similar names.
Offline LateLesley
  • Country: scotland
« Reply #22 on: November 09, 2019, 06:32:35 am »
Well, yeah, that is always the danger of going outside the known good suppliers.
And looking at the fraud page, it does look like the logo and name have similarities. Good catch. And A good warning to all us hobbyists.
Apologies for linking to them.
And thank you for the warning.
« Reply #23 on: December 07, 2019, 12:32:33 am »
I finally received a 10-pack I bought on AliExpress for $1.20 (1.92 with shipping) to give them a try.
https://www.aliexpress.com/item/32819577430.html
As I expected, they have slightly different color (brighter red), they are slightly longer, not rounded, and noticeably brighter.
I believe this should work fine if all LEDs are replaced, including green ones.
If someone really wants to do fine adjustments, in the unit they sit on spacers, so in principle they can be lowered, and they can, perhaps, be rounded, but that is a lot of work. I am not going to bother. They stick out a little, but it does not seem to be a problem to me.
So I am thinking about ordering one more 10-pack of red ones, and a 10-pack of green ones, and replacing all of them.
Offline Nedreud
« Reply #24 on: September 19, 2024, 07:26:19 pm »
I took a chance on a dead ES-1 mkII "RHYTHM PRODUCTION SAMPLER" from eBay and no surprise it didn't work when connected with the correct power supply.
Carefully comparing the schematic for the ES-1 mkI (I note it's "Provisional Version, Revision: 1.00" and therefore likely a leaked pre-production copy) and checking voltages on the board I was only getting +0.79V where I was expecting to find +5V for the DIGITAL section. I didn't spot it at first, but eventually noticed that the S8520 step-down switching regulator-controller is toast (IC39 on the board):
2376659-0
Not as dramatic as the melted mess on feeedback.loop's ER-1 mkII, but a very similar failure. They're protected from reverse polarity, but I don't think these devices can stand an over-voltage for too long. Spec sheet says 18V is the absolute maximum the S-8520 can handle. It's not clear if F3, the CPH6302 P-Channel MOS Silicon FET, is dead too, but neither of these things are more than a $/£/€ or so.
I note that the code on IC39 is BOJU, which makes in a S-8520F50MC-BOJT2U which is the S-8520 Series F, 5.0V output, 300kHz Osciallation Frequency with No Overload Protection and "Lead-free (Sn 100%), halogen-free"!
For future reference for anyone else that finds themselves in a similar situation, here is a photo of the power supply area. Note that this is the ES-1mkII KLM-2507 board. I believe it's functionally the same as the mkI, but the board itself has been revised because the component numbers don't make the mkI schematic:
2376663-1
And here is the PSU section of the schematic. Again note this is the mkI schematic for board KLM-2197, which I have overlaid with mkII component numbers in red (use at your own risk, this is my best guess tracing and inspecting the board):
2376679-2
Thanks again to feedback.loop for his invaluable YouTube videos.
