Hi All,
I am trying to repair a SMPS out of a Korg Triton, I am not having much luck as I don't usually work on mains stuff so I thought I would turn to the forum for assistance. The outputs are +5, +15 and -15, all the voltages read correct but when under load the voltages drop sharply; the +5 rail drops after about 1 amp load is applied, the +-15 volt rails drop with only 10ma on them (with or without the +5 volt load). I have tested Q1, Q2, Q3, Q5, PC1, IC1, IC3, IC4 and they all seem fine, the electrolytic Caps look fine, no signs of leakage or bulging. Could IC2 the voltage reference be the issue or one of the man
Triton PSU.pdf (71.59 kB - downloaded 77 times.)y Zenner or smd caps?
Kind regards,
Graham
