Author Topic: KRK rokit 5 speaker Part Identification  (Read 657 times)
Offline Maxwell55Topic starter
« on: September 06, 2024, 01:40:43 pm »
Hi, I'm hoping someone could help me identify 2 components on a KRK RP5 G3 mainboard. These are labeled ES0 and ES1 and are on the RCA plug circuit.
They blew up when I attached a hot RCA cable.   Thank you
« Last Edit: September 06, 2024, 01:43:31 pm by Maxwell55 »
Offline David_AVD
Re: KRK rokit 5 speaker Part Identification
« Reply #1 on: September 06, 2024, 11:26:31 pm »
How have you determined that they have failed?
« Reply #2 on: September 07, 2024, 01:12:32 am »
I've shown you a picture of the good speaker,
I've determined they're blown from the following picture of the failed speaker.
Have any idea what they are?
Offline fzabkar
« Reply #3 on: September 07, 2024, 01:25:49 am »
They appear to be bidirectional ESD protection diodes.
« Last Edit: September 08, 2024, 05:27:10 am by fzabkar »
« Reply #4 on: September 07, 2024, 01:33:18 am »
Thank you for replying, I thought is was some kind of diode but wasn't sure. I don't have any specs of those 2 parts. I'll try to shine a light sideways to see if it shows anything, otherwise how could I find a replacement?
Online gamerpaddy
« Reply #5 on: September 07, 2024, 01:53:44 am »
unusual package for a diode, they are usually encased in plastic not ceramic
ES might stand for ESD
i would have guessed a ferrite bead, but as its between signal and ground i think its more like a ESD protection
might be a varistor  https://www.meritekusa.com/product-category/esd-protection/esd-varistor/
desolder a working one, apply a voltage with a very low current limit and see when it starts clamping at.
« Reply #6 on: September 07, 2024, 03:03:12 am »
Unfortunately I don't have a power supply to be able to do such a test with one of those components. I'll have to find the part number
Offline David_AVD
« Reply #7 on: September 07, 2024, 06:32:25 am »
How did you send such a significant voltage into the audio input to start with?
Online gamerpaddy
The following users thanked this post: fzabkar
« Reply #9 on: September 07, 2024, 11:56:30 pm »
HI, thanks for the info, I managed to get close for a shot in many angles, I am able to see some markings on one of them but unable to determine exactly what it says.
I'll see if I can try to get a better shot, I'll include it, maybe you can detremine what it says?
