Hello everyone!
Here I am again with another one, which has priority over my HP 6274b power supply
This is a 6" active monitor speaker, this week out of nothing it made a loud noise and suddenly let out the magic smoke, a LOT of it. Opened it up and oh god, the smell. The tweeter measured open right off the bat, so that's dead. I didn't test the woofer yet but it measured 1.9ohms, however shorting the leads also gives 1.9ohms... Didn't get to measure impedance or test it with another amp.
So I took the amplifier board out of the cabinet (forgot to take pictures of the whole speaker
but I attached one from the internet), no obvious signs on it of anything bad other than some goo to fix capacitors and parts in place. They used hot glue a lot, but I question the yellowish circles around C10, C9... theres a picture with a zoom on them. Are those some adhesive or leakage? I have an el cheapo transistor tester from ebay which I guess can help me test capacitors along with fluke 179 capacitance meter.
So I went to power up the board. The supply rails for output ICs seem fine at around +/- 29,5V each.
Feeding a 0.3Vpp sinwave and checked the output with the osciloscope (blue = woofer output, yellow = tweeter output, purple = signal gen)
I swear I had both tweeter and woofer having a sinwave at one point, and their amplitude changed as I changed the frequency, tweeter going higher as amplitude got higher, inverse for woofer. But that didn't last long. All of a sudden both outputs were at 14VDC.
Powered off the unit and after powering it on again, woofer had a sinewave and tweeter not. I hooked up an old woofer to it and it sounded pretty nice, so I guess that rules off amplifier IC.
Then measured the two linear regulators on the board for +15v/-15V. +15V one was hot to the touch, while the -15V was warm.
Here comes the interesting part:
+15V reg (HOT): Vin = 25.5V, Vout = 15.08V
-15V reg: Vin = -26,2V, Vout = -13,74V and dropping a bit more... until it went to -0.67V. At this point, the woofer output which was doing fine went to a fixed DC level again!
So I'm guessing theres something wrong on one the opamps (theres 5 TL072CN ) which is dragging the rail voltage down or... the capacitors?
Can anyone shed some light? I tried looking for a schematic to no success.
As a sidenote, we have 5 of these in the same studio, they were stored for 5-10 years in the box and put into usage at the start of this year, so they are sorta new old stock
More & Higher res pictures:
https://drive.google.com/open?id=1-53U3BguL3Rvb073eWsImBWB0wsSNNfEOutput ICs are LM3886TF, one for each
Any input is appreciated!
Yours,
Luciano
